GS1900 individual port IGMP defeat
Brett_AV
Brett_AV Posts: 2 image  Freshman Member
Hi all!
I'm new to the ZyXEL universe, so I'm having trouble on configuring one aspect of my new GS1900-10HP. I'd like to set up a couple of ports without IGMP snooping, to leave it running on the rest. In Cisco, there's a forwarding or individual port on/off for IGMP, but it looks like the GS1900 configuration has "static" and "forbidden" options for individual ports. Do I just set the ports of interest to "static"? It seems too easy!
Seems like a dumb question, but I'm just trying to wrap my head around a different set of terms for what I assume to be identical features.
Thanks!
Brett
  • Zyxel_Tina
    Zyxel_Tina Posts: 701 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @Brett_AV,
    Welcome to Zyxel Community!
    Based on your description, setting the desired ports to static is the correct approach on the GS1900.
    If you run into any problems after applying the setting, feel free to share more details such as your topology and current configuration. This will help us better understand the scenario and provide more accurate assistance.
    Zyxel Tina
  • Zyxel_Tina
    Hi @Brett_AV,
    Zyxel Tina
  • Brett_AV
    Thanks so much Tina!
