USG FLEX 200H And 500H Reserved IP
Gred57
Gred57 Posts: 6 image  Freshman Member
Here's my problem: when I reserve an IP address, some devices are set to Reserved, while others disappear from the list.
Everything works normally, except I can't release the IP address if I need to.
How can I regain control?
I haven't found anything on this topic.
Sincerely,
Fred
Best Answers
    PeterUK Posts: 4,228 image  Guru Member
    edited July 18 Answer ✓
    I believe this is a know issue if host names are the same even if the MAC's are different.
    So the best way to deal with this is set DHCP lease time to 3 minutes (which will not cause a drop in connection on renew) then you will start seeing device renew then to reserve a device that has the same host name copy its MAC check it and release it then click add and give it a new host name (note this will not change the device host name that it says it is) IP with the copied MAC and then that device will use that IP.
  • Zyxel_Tina
    Zyxel_Tina Posts: 402 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 50 Answers First Comment
    edited July 21 Answer ✓
    Hi @Gred57,
    We tried reproducing the issue on our side, but so far we haven't encountered the same behavior.
    To better understand what's happening, could you please provide a screen recording of your steps, showing how the problem occurs?
    This would really help us see the full context and assist you more accurately.
    Thanks in advance!
    Zyxel Tina
  • Gred57
    Hello, you're right, the native hostnames were identical. I changed the hostnames directly on the hardware, and now it's fine.
    Thank you.
    Sincerely,
  • Gred57
    I have completely different host names, but they contained a forbidden character, _, which I replaced with -.
    I restarted the USG, and that didn't fix my problem.
    I'll change the lease duration on Monday and let you know.
    Thank you for your reply.
    Have a good weekend.
  • Zyxel_Tina
    Hi @Gred57,
    Thanks in advance!
    Zyxel Tina
  • Gred57
    Thank you.
    Sincerely,
  • Gred57
    Hi Tina.
    Changing the hostname on the USG 200H or 500H
    E.g., Native hostname of device 1: device1 changed to hostnamedevice1
    Native hostname of device 2: device1 changed to hostnamedevice2
    makes lines with identical native hostnames disappear, even though I changed their names.
    Native hostname of device 1: device1 changed to hostnamedevice1 -> Reserved
    Native hostname of device 2: device1 changed to hostnamedevice2 -> Reserved -> Lines disappear.
    There you go.
    Best regards
