ZyWALL110 Error Number: -16015 Error Message: 'Dial a dynamic tunnel has failed for Crypto map.'
Еhanks. I have fulfilled your recommendations, but the situation has not changed0
I do not understand why this does not work. all settings are made according to the instructions from zyhel.
I am grateful that you help me in solving the problem0
looks like a bug in phase 2 (local policy)
Dear customer
I don't believe this is a bug: can you send me you Telephone number or remote access in a Private Message we can then check the config...0 -
Thank you all! The problem was that as a test computer I used a home with Windows 10, and VPN started working after "regedit"==> "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\PolicyAgent"==>parameter "AssumeUDPEncapsulationContextOnSendRule" "Value Data" it was changed from "2" on "1". I express special thanks to the user "[Zyxel] jonatan" for actively participating in solving my problem.
Hi @Vyacheslav
The registry key 2 you mentioned is for establish VPN when both USG and client are behind NAT router. In your scenario, USG should not behind NAT, the value 1 is enough.
It’s good to hard you resolved the issue.
- 588 USG FLEX H Series
- 476 News and Release
