A XS1930-28
PeterUK
PeterUK Posts: 4,356 image  Guru Member
Will one day want a ideally a 26 all 10Gb ports with two SFP+ 😁
2 votes
Active · Last Updated
  • Zyxel_Ivan
    Zyxel_Ivan Posts: 406 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Security
    Hi @PeterUK,
    Thank you for sharing this idea with us.
    Can you share the scenario with us? So that we can better understand your requirement.
    Thanks.
    Ivan
    Well I mean a bigger switch thats all 10Gb will happen right? in my case it will replace my GS2210-24 maybe why 26 ports that are 10Gb and 2 that are SFP+ is thats how I'm using my current switch so it be a easy swap.
  • Zyxel_Ivan
    Hi @PeterUK,
    It's good for us to know the scenario from you.
    It appears that you need a model to replace the GS2210-24, and the GS2220-28 does not meet your requirements.
    Have you considered the XS3800-28? It does not have 26 10Gb ports, but it has 12 10Gb ports and 10 SFP+ ports.
    Thanks.
    Ivan
    I guess this is something that will happen in a year or two and others are going to be interested
  • Zyxel_Ivan
    Hi @PeterUK,
    I checked with the team, we will have a model to fulfill your requirement in the near future!
    Please pay attention to our new product announcement.
    Thanks.
    Ivan
