WAN Ports have no connection after restart
Alexander_Blüthl
Alexander_Blüthl Posts: 2 image  Freshman Member
i migrated two Flex 100 to Flex 100 H and experience at both the same behaviour.
After a restart, the WAN ports have no connection. I have to manually unplug the cables from the port. After that, the port starts getting IP via DHCP, or with static IP traffic start flowing.
Does anybody have a solution?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @Alexander_Blüthl
    Thanks for your cooperation. This issue has been addressed and will be included in the future firmware release.
    Zyxel Melen
  • Zyxel_Melen
    Thanks for pointing this out! I want to clarify with you:
    1. Could you share the converted configuration with me? You can send the file to me via private message.
    2. When did you do the configuration convert?
    Zyxel Melen
  • Zyxel_Melen
    Zyxel Melen
