Flex H, a rant
13»
  • Trilogy
    Trilogy Posts: 7 image  Freshman Member
    Did you guys have the courage to upgrade to the new firmware 1.35(ABZI.0) released a couple of days ago to see if it improves your situation or at least some of the pending issues?
    I just upgraded and Tailscale no longer worked after that. Disabling and re-enabling the feature made the device appear "online" in the Tailscale portal for maybe 10 seconds, after that it went "offline" again.
    Solution: Revoke the key on the Zywall, remove the device in the Tailscale portal, and then re-add the device using a new key. Now it works again as intended.
  • MCFH
    MCFH Posts: 19 image  Freshman Member
    First Comment Friend Collector Eighth Anniversary
    edited July 2025
    feeling a bit underwhelmed by the release notes - I can’t see any of the disclosed feature gaps having been closed…
  • Dylan96
    Dylan96 Posts: 35 image  Freshman Member
    Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security First Comment Friend Collector
  • weite
    weite Posts: 33 image  Freshman Member
    First Comment Eighth Anniversary
    Okay, the new version is running so far and the menutree is in bold. But that's all.
    There's no next-hop policy routing here either. HA is still in beta, and the secondary peer gateway for VPN failover and fallback isn't implemented. All of this is needed in a production environment.
    Does Zyxel have a plan? I don't understand why anyone sell a firewall in beta.
    Can anyone of zyxel exactly say when the features of the list that are not yet supported by uOS products will be implemented?
    PeterUK Posts: 4,381 image  Guru Member
    edited July 2025
    Well everyone uses part of the USG Flex H different to anyone else and so testing is needed whats done so far some will be happy with.
    This is getting really old
    “ Please note that your new firmware download feature is disabled due to ITS installed. Please contact local support to ensure the upgrade is applicable.”
    So I had to save my config and luckily have V1.32(ABWV.0) to boot to then load the config reboot then made nebula upgrade me which I don't think was meant to happen I did see a note saying firmware in mid August but it updated so here I am.
    What I will say about V1.35 the UI feels faster🙂
