Flex H, a rant
Did you guys have the courage to upgrade to the new firmware 1.35(ABZI.0) released a couple of days ago to see if it improves your situation or at least some of the pending issues?
I just upgraded and Tailscale no longer worked after that. Disabling and re-enabling the feature made the device appear "online" in the Tailscale portal for maybe 10 seconds, after that it went "offline" again.
Solution: Revoke the key on the Zywall, remove the device in the Tailscale portal, and then re-add the device using a new key. Now it works again as intended.
feeling a bit underwhelmed by the release notes - I can’t see any of the disclosed feature gaps having been closed…
Okay, the new version is running so far and the menutree is in bold. But that's all.
There's no next-hop policy routing here either. HA is still in beta, and the secondary peer gateway for VPN failover and fallback isn't implemented. All of this is needed in a production environment.
Does Zyxel have a plan? I don't understand why anyone sell a firewall in beta.
Can anyone of zyxel exactly say when the features of the list that are not yet supported by uOS products will be implemented?
Well everyone uses part of the USG Flex H different to anyone else and so testing is needed whats done so far some will be happy with.
This is getting really old
“ Please note that your new firmware download feature is disabled due to ITS installed. Please contact local support to ensure the upgrade is applicable.”So I had to save my config and luckily have V1.32(ABWV.0) to boot to then load the config reboot then made nebula upgrade me which I don't think was meant to happen I did see a note saying firmware in mid August but it updated so here I am.
What I will say about V1.35 the UI feels faster🙂
- 441 Beta Program
- 530 USG FLEX H Series
- 332 Security Ideas
- 51 Wireless Ideas
- 292 Service & License
- 461 News and Release
