XMG1915-18EP Power Supply Range
mmain2025
mmain2025 Posts: 1 image  Freshman Member
Hi folks I live in Vietnam and struggling to find a supplier without a mandatory 3 year Nebula subscription at ~$900, so I am looking further afield to buy this unit and just want to check the power supply has a wide input voltage / frequency range, and not 120 V 60 Hz for USA version? Many thanks in advance.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @mmain2025
    The power input of XMG1915 series is 100 - 240V AC, 50/60 Hz. So, you don't need to worry about the input power issue.
    However, purchasing from further afield could lead to warranty issues. Please assess the risk before making a purchase.
    Zyxel Melen
  • Zyxel_Melen
    Hi @mmain2025
    Zyxel Melen
