XS1930-10 Vendor ID Based VLAN -Error: No more free entry for Vendor-ID based VLAN
Hi @Av3ng3r
The maximum number of Vendor-ID based VLAN is 8 for plus and pro.
May I know if you have already set 8 vendor ID configuration in your site?
Zyxel Melen0 -
Yes I already have 8 Vendor ID.
What is the process to have the ability to add more?0 -
Hi @Av3ng3r
Since the maximum number is 8, setting more vendor IDs is not available through the usual method. Could you share how many vendor IDs you will set? I will help you check which process can help you reach this requirement.
Zyxel Melen0 -
Hi @Av3ng3r
Also, what the scenario that you need to create that much Vendor ID VLAN? Could you share with us?
Zyxel Melen0 -
revisiting the question.
What is the process to enable more Vendor ID Vlans?
I need to configure at least 16 Vendor Vlans.I would appreciate your guidance.
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
