XMG1915-10E catch 22
cbeckstein
cbeckstein Posts: 22 image  Freshman Member
edited July 2025 in Switch
Is there really no way from within the Web interface of a standalone XMG1915-10E (latest official FW V4.80(ACGO.3) | 11/26/2024) to change it from using a static IP to using a management network setup governed by DHCPV4?
When I change the IPV4 static interface from static to DHCP a new interface with same VID 1 and both gateway and mask 0.0.0.0 (index 1, old static interface now has index 2) shows up.
When I then try to delete the old static interface the router refuses it with the comment: first unset gateway (apparently because it is in use by the static interface).
And any attempt to erase the gateway or set it to 0.0.0.0 results in a: invalid IP message…
So catch 22: to delete the static interface I have to unset the gateway and to unset the gateway I first have to delete the static interface using it…
I eventually solved the problem via ZON, but still: there really should be a way to make the switch from static to DHCPV4 completely from within the Web interface…
  • Zyxel_Lynn
    Zyxel_Lynn Posts: 101 image  Zyxel Employee
    edited July 2025 Answer ✓
    Hi @cbeckstein ,
    I have reproduced the similar issue and obtained the same results as you reported. This matter is currently under internal review and investigation. Any updates or developments regarding this issue will be communicated to you promptly upon availability.
    Best Regard,
    Lynn
  • Zyxel_Lynn
    Hi @cbeckstein ,
    Best Regard,
    Lynn
  • Zyxel_Lynn
    edited August 2025
    Hi @cbeckstein ,
    Following the internal review and investigation, you can switch the device's static IP interface to a dynamic IP interface using the web GUI management method.
    First, configure your default gateway as 0.0.0.0. in order to unset the default gateway.
    Then, click the static IP interface and edit it.
    Next, select the DHCP client and input the VID.
    At last, delete the original static IP interface, and then the device is now switched into the DHCP IP interface.
    I hope this helps resolve your issue. Please feel free to update this post if you run into any other problems or need further assistance.
    Best Regard,
    Lynn
