USG FLEX H V1.35 - IPSec connectivity check
p4_greg
p4_greg Posts: 31  Freshman Member
Network Detective-New Adventure Badge First Comment Friend Collector Third Anniversary
According to the release notes, Connectivity Check for IPSec VPN was implemented in this new firmware.
How can I configure this? I am not seeing it under the IPSec VPN settings.
    PeterUK Posts: 3,910  Guru Member
    Yes I see this too can't find it.
  • Zyxel_Tina
    Zyxel_Tina Posts: 99  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 5 Answers First Comment
    Hi @p4_greg and @PeterUK,
    Regarding the Connectivity Check feature for USG FLEX H Series devices, please note that it is not intended for configuration purposes. However, you can locate the “Connectivity Check” menu under VPN Status > IPSec VPN > Site to Site VPN to check the connection to a remote client through the VPN tunnel.
    Zyxel Tina
  • p4_greg
    That explains why I could not find it….I assumed the release notes were referring to the Connectivity Check which was previously available in the VPN Connection settings on the non-H/ZLD-based firewalls.
    It has been helpful in the past when the connection gets 'stuck' and traffic does not flow over the VPN, which sometimes happens after one side of the VPN connection experiences internet issues. The connectivity check feature available on previous would automatically detect this and reset the VPN connection, which usually restored connectivity.
    Are there any plans to add this feature back?
    Screenshot from VPN Connection settings on an old VPN100:
