ATP500 - LAG forgotten?
@HMS
Currently, there is not LAG feature on ATP models, and this function will be evaluated internally.
Also, I will move this case to idea section.
Charlie0 -
Hello and thank you for your answer.The ATP devices are the successors of the USG, it seems logical to me a feature available in an old model, also on a new model ...If not, how to create a Full-HA cluster with ATP without this feature?
With best regards.0 -
@HMS
ATP is an advance Security Gateway which is more focus on external threat protection part. It doesn’t mean to be a replacement for the USG series....
If the HA scenario is required, users may consider to deploy 2 ATP with HA Pro function.
The introduction of device HA-Pro from website as your reference.
Device HA-Pro
Charlie
Hello,What I mean by FULL HA Cluster:2 ATP operating in HA-Pro + 2 Stacked switches on WAN side + 2 Stacked switches on LAN side.The LAG function is necessarily necessary in this case.
@HMS
Yes, you are right. Regarding to your scenario,
currently, you may consider USG310, USG1100, and USG1900 which support LAG feature.
Charlie0 -
Hello and thank you for your answer.Indeed, we currently have a USG310 cluster that works perfectly this way.We also have a USG110 cluster (which is not Full HA) that we want to replace with an ATP500 cluster configured in the same way as our USG310 cluster.Thank you in advance for sharing our need for the LAG function with the development team.
Also top model ATP800 have no LAG... :-(We changed USG310 for ATP800 and LAN we must have connected to core switch by one LAN port...0
In the Handbook of the ATP model it shows the option of LACP and this leads to errors. Will this option be available soon on ATP models?
It is unfortunate that this problem is still not solved. We bought an ATP500 at the end of 2018, which we still can not put into service because of this lack of the LAG function.
- 397 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 78 Nebula Status and Incidents
- 5.1K Security
- 52 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 332 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 880 Nebula FAQ
- 415 Security FAQ
- 221 Switch FAQ
- 195 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 63 Security Highlight
