USG FLEX H V1.35 - IPSec connectivity check
p4_greg
p4_greg Posts: 39 image  Freshman Member
Network Detective-New Adventure Badge First Comment Friend Collector Fourth Anniversary
According to the release notes, Connectivity Check for IPSec VPN was implemented in this new firmware.
How can I configure this? I am not seeing it under the IPSec VPN settings.
Best Answers
  • Zyxel_Tina
    Zyxel_Tina Posts: 702 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @p4_greg and @PeterUK,
    Regarding the Connectivity Check feature for USG FLEX H Series devices, please note that it is not intended for configuration purposes. However, you can locate the “Connectivity Check” menu under VPN Status > IPSec VPN > Site to Site VPN to check the connection to a remote client through the VPN tunnel.
    Zyxel Tina
  • Zyxel_Tina
    edited August 2025 Answer ✓
    Hi @p4_greg,
    Sorry for the late reply!
    After double confirmation, the USG FLEX H series does not support direct configuration of connectivity check like the USG FLEX (ZLD) does.
    To achieve a similar function, the current workaround is to use a route-based VPN with a VTI interface to perform peer probing. However, if you use a policy-based VPN, connectivity check configuration is not available.
    For how to create VTI, please refer to this FAQ. After creating the interface, navigate to Network > Interface > Advanced Settings > VTI and select Edit to configure its connectivity check.
    Zyxel Tina
    PeterUK Posts: 4,427 image  Guru Member
    Yes I see this too can't find it.
  • Zyxel_Tina
    Zyxel Tina
  • p4_greg
    That explains why I could not find it….I assumed the release notes were referring to the Connectivity Check which was previously available in the VPN Connection settings on the non-H/ZLD-based firewalls.
    It has been helpful in the past when the connection gets 'stuck' and traffic does not flow over the VPN, which sometimes happens after one side of the VPN connection experiences internet issues. The connectivity check feature available on previous would automatically detect this and reset the VPN connection, which usually restored connectivity.
    Are there any plans to add this feature back?
    Screenshot from VPN Connection settings on an old VPN100:
  • Zyxel_Tina
    Hi @p4_greg,
    Zyxel Tina
