XGS1930 change management VLAN
nielsscheldeman
nielsscheldeman Posts: 74  Ally Member
I have a setup with 4 XGS1930-52HP switches and 3 GS1900-8HP switches. I want to move them to a separate management VLAN. Created VLAN11 and moved the GS1900 switches to that management VLAN. Created a rule on firewall so that 1 of my servervm's can access that VLAN. Works fine for the GS1900's
But If I add IP-Address with VLAN ID and change default gateway on XGS1930 I'm unable to access the switch from my VM on the new IP. If I set my VM in VLAN11 it works fine. Because the GS1900 series work fine I don't think it's firewall policy problem, but routing problem.
However if I ping from the other network to the switch's new IP it works fine and also telnet 443 works fine.
