Usg Lite 60AX failover connection?
Is it possible to use a secondary WAN connection as a failover on a USG Lite 60?
If so how should I go about configuring the device to do so.
Hi @LukeArchbold,
Unfortunately, the USG Lite 60AX only has one physical WAN port and does not support assigning LAN ports as a secondary WAN. Therefore, WAN failover using a second WAN interface is not supported on this model.
If WAN redundancy is a critical requirement, we recommend considering a model from the USG FLEX H/USG FLEX series, which supports dual WAN and offers WAN failover and load balancing features.
Zyxel Tina
From looking no.
Hi @LukeArchbold,
Zyxel Tina
- 601 USG FLEX H Series
- 480 News and Release
