Usg Lite 60AX failover connection?
LukeArchbold
LukeArchbold Posts: 14 image  Freshman Member
Is it possible to use a secondary WAN connection as a failover on a USG Lite 60?
If so how should I go about configuring the device to do so.
  • Zyxel_Tina
    Zyxel_Tina Posts: 310 image  Master Member
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 50 Answers First Comment
    Hi @LukeArchbold,
    Unfortunately, the USG Lite 60AX only has one physical WAN port and does not support assigning LAN ports as a secondary WAN. Therefore, WAN failover using a second WAN interface is not supported on this model.
    If WAN redundancy is a critical requirement, we recommend considering a model from the USG FLEX H/USG FLEX series, which supports dual WAN and offers WAN failover and load balancing features.
    Zyxel Tina
    PeterUK Posts: 4,162 image  Guru Member
    From looking no.
  • Zyxel_Tina
    Hi @LukeArchbold,
    Zyxel Tina
