ZyWALL110 Error Number: -16015 Error Message: 'Dial a dynamic tunnel has failed for Crypto map.'
2»
  • Vyacheslav
    Vyacheslav Posts: 17 image  Freshman Member
    Еhanks. I have fulfilled your recommendations, but the situation has not changed
  • Vyacheslav
  • Vyacheslav
    I do not understand why this does not work. all settings are made according to the instructions from zyhel.
  • Vyacheslav
    edited May 2019
    I am grateful that you help me in solving the problem
  • jonatan
    jonatan Posts: 200 image  Master Member
    5 Answers First Comment Friend Collector Eighth Anniversary
    looks like a bug in phase 2 (local policy)
  • [Deleted User]
    [Deleted User] Posts: 118 image  Ally Member
    5 Answers First Comment Friend Collector Fifth Anniversary
    Dear customer
    I don't believe this is a bug: can you send me you Telephone number or remote access in a Private Message we can then check the config...
  • Vyacheslav
    Thank you all! The problem was that as a test computer I used a home with Windows 10, and VPN started working after "regedit"==> "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\PolicyAgent"==>parameter "AssumeUDPEncapsulationContextOnSendRule" "Value Data" it was changed from "2" on "1". I express special thanks to the user "[Zyxel] jonatan" for actively participating in solving my problem.
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,435 image  Zyxel Employee
    Hi @Vyacheslav
    The registry key 2 you mentioned is for establish VPN when both USG and client are behind NAT router. In your scenario, USG should not behind NAT, the value 1 is enough.
    It’s good to hard you resolved the issue. :+1:
