two MG-108 switches cannot be found during discovery
markcampbell65
markcampbell65 Posts: 2 image  Freshman Member
two MG-108 switches cannot be found during discovery — I have a laptop connected to a wireless access point that is plugged directly in to the switch… do I need to be directly connected?
  • Zyxel_Tina
    Zyxel_Tina Posts: 466 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers First Comment
    Hi @markcampbell65,
    Welcome to Zyxel Community!
    The MG-108 is an unmanaged multi-gigabit switch, which means it does not have a web interface or support for device discovery via Nebula, ZON, or similar tools. That’s why it won’t appear during a discovery scan — regardless of whether you are connected via Wi-Fi or directly with a cable.
    If you simply want to verify the switch is working, you can try this method:
    Ping test
    • Connect two devices to different ports on the MG-108.
    • Make sure they are on the same IP subnet.
    • From one device, ping the other.
    • If you receive replies, the MG-108 is forwarding packets correctly.
    If you require remote management or discovery features, you may consider one of our managed switch models, such as XS1930-10 or XMG1915-10E, which fully supports these functions and also offers multi-gigabit capabilities.
    Zyxel Tina
  • Zyxel_Tina
    Hi @markcampbell65,
    Ping test
    Zyxel Tina
  • markcampbell65
    Thanks for this clarification..
