H series 1.35 FW download is impossible
Yes I get your point so in short the base firmware needs all the WAN config be it MAC, DHCP, static or PPPoE to get on your internet which is not the case at this time? guess Zyxel thinks you have a router setup to give a IP to a setting up device or your internet line will give a IP by DHCP but what if you don't then your stuck.
Update:
The firmware file download for USG FLEX H series will be available on August 20th in the Zyxel Download library.
Zyxel Melen2 -
Thanks a lot 😎
- 243 Nebula Ideas
- 6.9K Security
- 792 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
