USG Flex 700H - i need to revert to firmware 1.32 ASAP
Firmware 1.35 is too unstable for us - i need to revert back to 1.32 ASAP. How do i do that?
Zyxel, please PM me.
You can show the other boot slot
How to display the standby firmware partition on GUI? — Zyxel Community
Then select the standby and reboot to it
Thanks Peter.
Tried rebooting the standby partition with firmware 1.32- then it bootet with factory default settings and i could not load my config file from v1.35. We have 2 devices in HA.
I'm so much struggling with inbound connections being dropped to services that we host. Connections can be restored when i force a reboot with failover to secondary device.
Hi @DanniKool,
Regarding your note, "I could not load my config file from v1.35", this is because new features and enhancements introduced in the newer firmware can cause configuration incompatibility. This is also why we generally do not recommend downgrading.
Since you mentioned that the secondary device is working, we suggest backing up its configuration and restoring it to the primary device (the one currently running in factory default settings).
Additionally, as you initially mentioned that v1.35 has been too unstable for you, could you please share more details on what specific issues or symptoms you have experienced?
As a reminder,
- Before switching firmware versions, always make sure to back up your configuration to prevent data loss.
- Whenever an issue occurs, we recommend collecting a diagnostic info file so it can be analyzed effectively.
Zyxel Tina
Hi Zyxel_Tina
I'm communicating with Zyxel_Jeff in a PM regarding our issues. I've been given a beta firmware, from where i could narrow the issue down to DoS, which has been disabled for the moment.
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 327 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 4.3K FAQ
- 97 Security Highlight
