Where do I download the factory-default configuration file to reset an XGS-4526 switch?
I have an XGS-4526 but I forgot the administrator login. The manual says to reset the switch by loading the factory-default configuration through a console cable. Where can I download the factory-default configuration file?
Nevermind. I found that I had a copy of the firmware XGS-4526_400(BHN.2)C0.zip, extracted the .ROM, then followed the reset procedure and uploaded this .ROM. When it came up, the switch was reset and i was able to get into it using the default login and management IP addresses.
Good evening,
May i ask if you still own a copy of the firmware?
I wanted to setup an old switch and found out it hasnt been reseted yet, but currently i cant find any copy of the file anywhere.
In regards,0
- 234 Nebula Ideas
- 6.7K Security
- 723 USG FLEX H Series
- 371 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 316 Service & License
- 511 News and Release
- 99 Security Advisories
- 5.2K FAQ
- 89 About Community
- 116 Security Highlight
