GS1900-24
david_logsdon
in Switch
I have a brand new GS1900-24 and everytime I try to update the firware the connection resets. Its running a July-2022 2.7 firware revision and I want to bring it to current 2.9. I've tried it in Chrome, Edge, Opera, and on a linux machine running its default browser.
I used an Ubuntu 24.04TLS that directly connected to GS1900-24 to upgrade from 2.70 patch 3(2022) to 2.90 patch 1 with success by HTTP method.
Please try to:
- Directly connect to the GS1900 when processing firmware upgrade.
- Temporarily disable your operating system firewall during the upgrade process.
- Ensure TFTP/HTTP/HTTPS services are not blocked by your security software
- Check that your antivirus software isn't interfering with the upload process.
- If HTTP method still having issue, please try to use TFTP to upgrade.
- If you have any Windows PC, you may use ZON to upgrade your GS1900-24.
Zyxel Melen0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
