WAN Ports have no connection after restart
Alexander_Blüthl
i migrated two Flex 100 to Flex 100 H and experience at both the same behaviour.
After a restart, the WAN ports have no connection. I have to manually unplug the cables from the port. After that, the port starts getting IP via DHCP, or with static IP traffic start flowing.
Does anybody have a solution?
Thanks for your cooperation. This issue has been addressed and will be included in the future firmware release.
Zyxel Melen0
Thanks for pointing this out! I want to clarify with you:
- Could you share the converted configuration with me? You can send the file to me via private message.
- When did you do the configuration convert?
Zyxel Melen0 -
Zyxel Melen0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
