DHCP Option 61?
LukeArchbold
LukeArchbold Posts: 23 image  Freshman Member
Hi all,
Is there any way to set DHCP Option 61 on a USG Flex 100H
  • zyman2008
    zyman2008 Posts: 243 image  Master Member
    50 Answers First Comment Friend Collector Eighth Anniversary
    edited August 2025 Answer ✓
    Hi @LukeArchbold,
    Need to setup via CLI. Take interface ge1 as an example.
    > edit running
    running config# / vrf main interface ethernet ge1 ipv4 dhcp dhcp-client-identifier-ascii 12345678@skyd
    sl running config# commit running config# copy running startup
  • zyman2008
    Hi @LukeArchbold,
    > edit running
  • LukeArchbold
    Thank you
