VPN routing between three sites with new H series and legacy Flex and third party firewall
LarrY_FIN
LarrY_FIN Posts: 6 image  Freshman Member
First Comment Eighth Anniversary Nebula Gratitude
Hi!
Scenario, where we have site-to-site tunnel between site 1 (USG Flex 200) and 3rd party site. Now we would want to have vpn-connection from new site 2 (USG Flex 50H) to 3rd party site via site 1. With two USG FLEX firewall's this routing is possible with Policy routes. I have tried similar setup, so that between site 1 and 2 there is VTI and traffic is okay between sites 1 and 2, but I cannot get it to work from site 2 to 3rd party site via site 1. Is it possible to get routing work between three sites, if sites 1 and 2 have route-based vpn and site 1 and 3rd party has policy-based vpn? At least for now, I am not able to change site1 - 3rd party site vpn to route-based.
Best Regards
    PeterUK Posts: 4,417 image  Guru Member
    edited August 2025
    I take it all three sites have different LAN subnets? Such that we can say
    site 1 subnet 1
    site 2 subnet 2
    3rd party site subnet 3
    So with the VTI on site 2 a routing rule at the top of the list with
    incoming LAN subnet 2
    Destination Address subnet 3
    next hop VTI
    SNAT none
    then on site 1 routing rule at the top of the list with
    incoming VTI
    Source Address subnet 2
    next hop VPN tunnel to site 3
    With the Policy Control rules to allow the following this gets you from subnet 2 to subnet 3 then the problem is this 3rd party site needs to route the Destination subnet 2 down the VPN tunnel.
    when thats done you then might need a static route on site 1 with
    subnet 2
    interface VTI
