Lockout users by username or IP
QuiteSmart
QuiteSmart Posts: 67 image  Ally Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN
after reading another security idea I focused on how locking-out users with too much failed attempts really work.
Differently from my idea it does not lock the user while it lock its public IP
MY IDEA IS: add the choice in configure —> user group —> setting between locking by username provided and or by IP
this IMHO would be an advancement because:
  1. if you ban that it ip it might happen that you are banning even other users. scenario: 5 employees of the same company go to a conference, they need to connect to thei VPN, they all use the hotel's WiFi, the first users inserts the wrong password too many times, they are all stuck for 30 minuts (or the time set)
  2. an attacker can spoof it's IP every 5 attemps and apparently change it (via a vpn or whatever) and performe a brute force attack bypassing the lockout security settings
if one wants to be hyper protected i would leave the choice to block by IP and eventually by both
3 votes
Active · Last Updated
  • Emanuele_ss
    Emanuele_ss Posts: 5 image  Freshman Member
    Right!
    Blocking the IP address could be a bad decision. There could be employers working at an external location and they would all be blocked.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,531 image  Zyxel Employee
    Hi @QuiteSmart
    Let me summarize this idea in short: You hope the "User Lockout Settings" not just block IP address, but also block the user/admin account that trying to login. Is it correct?
    Zyxel Melen
  • QuiteSmart
    edited August 2025
    Hello @Zyxel_Melen thank you for your interest in my idea.
    To be more precise not "also" but and/or that would be that the administrator can decide which behavior will occour when the threshold is reached:
    1. block the user for xx minutes (if the type user exists)
    2. block the IP for xx minutes
    3. block both user both ip for xx minutes
    PS it is interesting to understand what would happen if the user "Melen" is currently connected to the VPN and an attacker tries to connect using that exact user but with wrong passoword(scenario where on the firewall an user is allowed to connect more than once at a time): if in this case Malen is locked would this affect the real Malen user already connected? Because this can turn into a DoS scenario
  • Zyxel_Melen
    Thanks for the detail information. @QuiteSmart
    We will monitor this idea's comments and votes for evaluation.
    Zyxel Melen
