H series router no hot fields in GUI
electsystech
electsystech Posts: 57  Ally Member
First Answer First Comment Friend Collector Sixth Anniversary
This is a feature request for 'hot fields' to be returned to the router GUI. We don't want to drill down every time to make a selection and we don't want the mouse to be the sole method for object selection.
Example 1
Example 2
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,810  Guru Member
    Hi @electsystech
    I will help to create an idea post for you. Before that, I want to mention the example 2 is more likely a filter behavior problem. If you type "us", you can find the United States option. We are investigate this part and I will keep you posted.
    Zyxel Melen
  • Zyxel_Melen
    edited August 21
    Hi @electsystech
    Here is the idea post link
    H series router no hot fields in GUI — Zyxel Community
    Our team will monitor this idea post's comments and votes to evaluate it.
    About the second issue, this has been addressed and will be enhanced in future firmware release.
    Zyxel Melen
