ssl vpn to dynamic ipsec
Hi @Boris
Please help to identify where the traffic been dropped, failure test:
- Ping the SSL VPN IP of Zywall USG in Head office.
- Ping the LAN interface IP of Zywall USG in Head office.
- Ping the LAN interface IP of Zywall USG in Branch office.
In addition, did you set policy route and static route on both of your Zywall USG?
Zyxel Melen0 -
1.Ping the SSL VPN IP of Zywall USG in Head office.
works
2. Ping the LAN interface IP of Zywall USG in Head office.
works
3. Ping the LAN interface IP of Zywall USG in Branch office.
no answer
Moreover, I can see in Zywall logs that packets successfully forwarded from SSL VPN to IPSec tunnel, but I cannot find it in Branch Office logs
Hi @Boris
Please help to check if you have these required configuration on both of your firewalls.
Site A:
- Create a policy route (Network > Routing > Policy Route)
- source: SSL VPN subnet
- destination: 192.168.80.x(SiteB)
- next-hop: VPN tunnel, select the S2S tunnel to SiteB
- Security Policy (Security Policy > Policy Control)
- To: IPSec_VPN
- action: allow
- SSL VPN Network (VPN > SSL VPN > Access Privilege)
- Edit the SSL VPN policy, add 192.168.80.x(siteB) into the Network List.
Site B:
- source: 192.168.80.x(SiteB)
- destination: SSL VPN subnet
- next-hop: VPN tunnel, select the S2S tunnel to SiteA
- To: IPSec_VPN
- action: allow
Zyxel Melen0 - Create a policy route (Network > Routing > Policy Route)
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 482 News and Release
