XS1930-10 Vendor ID Based VLAN -Error: No more free entry for Vendor-ID based VLAN
Av3ng3r
Av3ng3r Posts: 14  Freshman Member
I am receiving the error "Error: No more free entry for Vendor-ID based VLAN".
I assume I can do more but I need to pay for a license.
Can someone share more information about the error, please?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,690  Zyxel Employee
    Hi @Av3ng3r
    The maximum number of Vendor-ID based VLAN is 8 for plus and pro.
    May I know if you have already set 8 vendor ID configuration in your site?
    Zyxel Melen
  • Av3ng3r
    edited July 29
    @Zyxel_Melen
    Yes I already have 8 Vendor ID.
    What is the process to have the ability to add more?
  • Zyxel_Melen
    Hi @Av3ng3r
    Since the maximum number is 8, setting more vendor IDs is not available through the usual method. Could you share how many vendor IDs you will set? I will help you check which process can help you reach this requirement.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Av3ng3r
    Also, what the scenario that you need to create that much Vendor ID VLAN? Could you share with us?
    Zyxel Melen
  • Av3ng3r
    edited August 26
    @Zyxel_Melen
    revisiting the question.
    What is the process to enable more Vendor ID Vlans?
    I need to configure at least 16 Vendor Vlans.
    I would appreciate your guidance.
