700H wireless. How to I adjust each AP transmitter power?
jef
jef Posts: 90 image  Ally Member
Looking for: "Overwrite Group Output Power Setting" for a given AP.
Heat mapping our 6th floor and I need to turn down that AP's transmit power.
On the USG 700 is was easy, you clicked on the AP in the "Mgt. AP List" to adjust it.
How do I the same thing on the 700H?
Best Answers
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317 image  Guru Member
    Hi @jef ,
    Current Workaround: To change the output power for a specific AP, you must currently move that AP to a new AP group and configure the power settings there.
    Upcoming Enhancement: In October, we will add a feature that allows you to override group output power settings for individual APs within a group, similar to the functionality available in USG FLEX 700.
    For updates on USG FLEX H firewall's new features and enhancements, please follow our Security News & Releases.
    Zyxel_Judy
    Untitled Image
  • jef
    I did not know that. Thanks Judy.
  • Zyxel_Judy
    Hi @jef ,
    Zyxel_Judy
    Untitled Image
  • jef
    Thanks, but I can't move it to a different AP group, it would not be part of roaming.
  • Zyxel_Judy
    Hi @jef ,
    APs don't need to be in an AP group to enable wireless client roaming.
    The roaming process can be achieved by configuring the same SSID name and security settings across your AP (AP groups). Additionally, ensure there is 15-20% overlapping coverage between APs.
    Zyxel_Judy
    Untitled Image
  • jef
  • jef
    Is this still planned? It would be nice to control APs in the same group, without having to make a group for each AP you wanted to tune.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,937 image  Guru Member
    Hi @jef
    Yes, this is still planned in the following firmware version V1.36.
    Zyxel Melen
