FQDN problem www.grc.com vs grc.com under wildcard
USG FLEX 700H V1.35(ABZI.1)
So I'm building a trusted FQDN list (including 3rd party for sites to load fine) for HTTPS mostly it works fine but have found a problem that ZLD is doing correctly but not uOS.
So if I have FQDN
*.grc.com
Go to www.grc.com it loads fine but if I try grc.com it does not and I think the problem has to do with the IP lookup for each so if I go www.grc.com the IP is 4.79.142.202 then if I go to grc.com the IP is 4.79.142.200 but I never see IP 4.79.142.200 for *.grc.com in IPv4 Cache List but in ZLD it Caches both IP's correctly.
Could this be fixed please
Edit more info
On old ZLD you can do
*grc.com
or
*.grc.com
but with the new uOS you can only do
*.grc.com
with ZLD and *grc.com it Caches both grc.com and www.grc.com
Hi @PeterUK,
We understand your requirement.
However, currently the USG FLEX H does not support the format*grc.com.
The supported wildcard format remains*.domain.com, which covers only subdomains but not the root domain.We have forwarded your feedback as a feature request (idea) for future consideration.
If anyone likes this idea, please show your support by leaving a comment or voting for it.
Zyxel Tina
- 217 Nebula Ideas
- 583 USG FLEX H Series
- 297 Service & License
- 476 News and Release
