DNS: How to set up a private Domain Zone Forwarder
Ich
Ich Posts: 5 image  Freshman Member
To resolve local DNS entries, I set up Domain Zone Forwarders (System|DNS) for the locally resolved domains.
Up to the classic USG Flex Series I was able to chose to set up "private servers". These where queried via "tunnel" which worked locally AND via VPN tunnel. The new USG Flex H series firewall forces me to chose the query via interface. Possible values are the physical and virtual network interfaces, but not the VPN tunnels.
Does anybody know how to set up DNS server hiding behind VPN tunnels?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @Ich
    It is in our feature list, but we don't have a ETA currently.
    Zyxel Melen
    Does selecting auto help?
    If you do a VTI tunnel you can query via that interface
  • Ich
    edited August 2025
    Auto is not available for "Domain Zone Forwarders"; only for "Global Zone Forwarders"…
    Until now I did never use VTI tunnels. Frankly, I don't understand, why they exist. I'll have to investigate into them a little bit more…
  • Zyxel_Melen
    Hi @Ich
    Since currently policy-based site-to-site VPN is not supported to select, we recommend to change your VPN setting from policy-based to route-based.
    You may feel free to provide your configuration and we will help to convert the VPN setting from policy-based VPN to route-based VPN. Please send me your configuration file to me via private message.
    Zyxel Melen
  • Ich
    You said "currently not supported"…
    Do you - or anyone else - know, if it is planned to restore the previous functionality?
  • Zyxel_Melen
    Hi @Ich
    Zyxel Melen
