FQDN problem www.grc.com vs grc.com under wildcard
PeterUK
PeterUK Posts: 4,437 image  Guru Member
edited August 2025 in USG FLEX H Series
USG FLEX 700H V1.35(ABZI.1)
So I'm building a trusted FQDN list (including 3rd party for sites to load fine) for HTTPS mostly it works fine but have found a problem that ZLD is doing correctly but not uOS.
So if I have FQDN
*.grc.com
Go to www.grc.com it loads fine but if I try grc.com it does not and I think the problem has to do with the IP lookup for each so if I go www.grc.com the IP is 4.79.142.202 then if I go to grc.com the IP is 4.79.142.200 but I never see IP 4.79.142.200 for *.grc.com in IPv4 Cache List but in ZLD it Caches both IP's correctly.
Could this be fixed please
Edit more info
On old ZLD you can do
*grc.com
or
*.grc.com
but with the new uOS you can only do
*.grc.com
with ZLD and *grc.com it Caches both grc.com and www.grc.com
  • Zyxel_Tina
    Zyxel_Tina Posts: 717 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    edited August 2025
    Hi @PeterUK,
    We understand your requirement.
    However, currently the USG FLEX H does not support the format *grc.com.
    The supported wildcard format remains *.domain.com, which covers only subdomains but not the root domain.
    We have forwarded your feedback as a feature request (idea) for future consideration.
    If anyone likes this idea, please show your support by leaving a comment or voting for it.
    Zyxel Tina
    Thanks Tina
    I have to hope they will make the change.
