ssl vpn to dynamic ipsec
Boris
Boris Posts: 3  Freshman Member
First Comment Seventh Anniversary
Computer conneted with SSL VPN to Zywall USG in Head office can not ping device in remote office via Dymaic site to site IPSec between Head and Branch office, but it works if I configure "ordinary" site to site IPSec.
How can I fix it?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,692  Zyxel Employee
    Hi @Boris
    Please help to identify where the traffic been dropped, failure test:
    1. Ping the SSL VPN IP of Zywall USG in Head office.
    2. Ping the LAN interface IP of Zywall USG in Head office.
    3. Ping the LAN interface IP of Zywall USG in Branch office.
    In addition, did you set policy route and static route on both of your Zywall USG?
    Zyxel Melen
  • Boris
    1.Ping the SSL VPN IP of Zywall USG in Head office.
    works
    works
    no answer
    Moreover, I can see in Zywall logs that packets successfully forwarded from SSL VPN to IPSec tunnel, but I cannot find it in Branch Office logs
  • Zyxel_Melen
    Hi @Boris
    Please help to check if you have these required configuration on both of your firewalls.
    Site A:
    1. Create a policy route (Network > Routing > Policy Route)
      1. source: SSL VPN subnet
      2. destination: 192.168.80.x(SiteB)
      3. next-hop: VPN tunnel, select the S2S tunnel to SiteB
    2. Security Policy (Security Policy > Policy Control)
      1. From: SSL_VPN
      2. To: IPSec_VPN
      3. source: SSL VPN subnet
      4. destination: 192.168.80.x(SiteB)
      5. action: allow
    3. SSL VPN Network (VPN > SSL VPN > Access Privilege)
      1. Edit the SSL VPN policy, add 192.168.80.x(siteB) into the Network List.
    Site B:
      1. source: 192.168.80.x(SiteB)
      2. destination: SSL VPN subnet
      3. next-hop: VPN tunnel, select the S2S tunnel to SiteA
      1. From: LAN
      2. To: IPSec_VPN
      3. source: 192.168.80.x(SiteB)
      4. destination: SSL VPN subnet
      5. action: allow
    Zyxel Melen
