Static ARP Table
Ich
Ich Posts: 5 image  Freshman Member
With the USG series I used a little CLI script to set up static ARP table entries (these entries are required to forward WoL packets from VPN connected management stations).
Example:
configure terminal
arp 10.1.1.1 12:23:34:56:67:78
exit
write
How can I achieve a static ARP table entry with the current USG Flex H series?
Thanks in advance…
  • zyman2008
    zyman2008 Posts: 242 image  Master Member
    50 Answers First Comment Friend Collector Eighth Anniversary
    Hi @Ich ,
    You can try this CLI.
    In case the client is under LAN interface ge3.
    IP address is 192.168.168.100 with MAC address 00:11:22:33:44:55
    > edit running
    # / vrf main interface ethernet ge3 ipv4 neighbor 192.168.168.100 link-layer-address 00:11:22:33:44:55
    # commit
    # copy running startup
    # show arp-table
  • Zyxel_Tina
    Zyxel_Tina Posts: 693 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @Ich,
    Thank you for raising this question.
    After confirmation, we can confirm that the current USG FLEX H series does not support configuring static ARP entries. We will forward your requirement as a Feature Request to our development team for further evaluation and also create an idea post for you.
    If anyone likes this idea, please show your support by leaving a comment or voting for it.
    Zyxel Tina
  • zyman2008
    Hi @Ich ,
    > edit running
    # commit
    # show arp-table
  • Ich
    Thank you. This works great 😀
    Would be nice, if the "ipv4 neighbor" command would sneak into the reference guide…
