Static ARP Table
With the USG series I used a little CLI script to set up static ARP table entries (these entries are required to forward WoL packets from VPN connected management stations).
Example:
configure terminal
arp 10.1.1.1 12:23:34:56:67:78
exit
write
How can I achieve a static ARP table entry with the current USG Flex H series?
Thanks in advance…
Hi @Ich ,
You can try this CLI.
In case the client is under LAN interface ge3.
IP address is 192.168.168.100 with MAC address 00:11:22:33:44:55
> edit running
# / vrf main interface ethernet ge3 ipv4 neighbor 192.168.168.100 link-layer-address 00:11:22:33:44:55
# commit
# copy running startup
# show arp-table
Hi @Ich,
Thank you for raising this question.
After confirmation, we can confirm that the current USG FLEX H series does not support configuring static ARP entries. We will forward your requirement as a Feature Request to our development team for further evaluation and also create an idea post for you.
If anyone likes this idea, please show your support by leaving a comment or voting for it.
Zyxel Tina
Hi @Ich ,
> edit running
# commit
# show arp-table
Thank you. This works great 😀
Would be nice, if the "ipv4 neighbor" command would sneak into the reference guide…
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
