ATP500 VLAN on one port untagged
Hi
Is it possible, to assign one free port on the ATP500 to a VLAN, untagged? I have one trunk that leads to a main switch, but the switch is in a different room. And there is one system next to the ATP, that belongs to VLAN19. Do i need an additional switch next to the ATP?
Thank you.
Stefan
Any VLAN you do on the ATP will be tagged you cant have a untagged VLAN where by one port tag traffic and the other grouped for the same subnet untag.
so you need a simple VLAN switch
GS1200 Series | 5-Port/8-Port Web Managed Gigabit Switch - Overview | Zyxel Networks
The other way is to use a port group untag one off to device other to where your main switch is for VLAN19 takes it untag to be on the VLAN19
Okay, thank you.
I'll have to get the switch then.0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
