setup vpn subscription
SNC
SNC Posts: 6 image  Freshman Member
First Comment Seventh Anniversary
I'm looking to setup active directory credentials for use as vpn. using the vpn subscription license. Cannot seem to find the steps to perform the task. Can someone point me in the right direction?
also, how do I get the master vpn license so the activation email will read hostname@company.com?
  • Zyxel_Tina
    Zyxel_Tina Posts: 471 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers First Comment
    Hi @SNC,
    You don’t need a VPN license to use Active Directory credentials for VPN login — this feature, such as SSL VPN or IPsec, is supported on the USG FLEX H Series for free.
    For the setup steps, please refer to this FAQ which provides the detailed configuration guide.
    Zyxel Tina
