Plastics - What Mix?
Mxman
Mxman Posts: 3 image  Freshman Member
We need to know the exact plastics mix used in the new NWA110BE & NWA130BE.
This is required to select the correct Velcro as in our situations we cannot drill.
We have been using an Velcro approved hook/loop which matched the previous none BE models.
We expect the recycling of plastics has created a new plastic mix.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,463 image  Zyxel Employee
    Hi @Mxman
    I'm not sure how you plan to use the Velcro to hook/loop the AP, but if you intend to use the bracket to secure the AP with the Velcro, the bracket is made of PC + ABS. Please feel free to share more details if you need further helps.
    Zyxel Melen
  • Zyxel_Melen
    Hi @Mxman
    Zyxel Melen
