GS1920 - API
Hi @acognard
No, there's no API to change POE settings.
In Nebula cloud mode, you can check the per port POE PD status via API with Nebula OpenAPI.
In standalone mode, you can use SNMP to check per port POE PD status and change POE setting.
Zyxel Melen0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
