Flex700 V5.40(ABWD.0) unable to get BWM working.
2»
  • peter2cfts
    peter2cfts Posts: 7 image  Freshman Member
    I'm gong to setup a simple vm, I'm missing something it should not be this hard.
  • Zyxel_Tina
    Zyxel_Tina Posts: 694 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @peter2cfts,
    Could you please share the detailed configuration of the objects, such as VPS_Malicard_UI, used in your BWM rules? From the screenshot you provided, we’re unable to confirm whether the object configuration matches your intended setup, so having this information will help us check if everything is set up correctly.
    In addition, for testing purposes, we’d recommend creating a simple rule using Source = any and Destination = any, with a smaller bandwidth limit applied on both inbound and outbound directions. This will help verify whether the BWM function itself is working as expected.
    Zyxel Tina
