open port usg50 flex
So if you have any rules with WAN to Zywall you want to deal with them as for Admin Service Control you want to do to two accept rules change the top one to zone LAN and the next one down to deny which overrides the bottom one.
Hi @baudetd,
You can achieve this in two ways on the USG50 Flex:
1. Check the Security Policy
Go to Configuration > Security Policy > Policy Control.
By default, the “WAN to ZyWALL” policy does not include ports 80 (HTTP) and 443 (HTTPS), meaning access from the WAN is already blocked.
However, if the policy’s Default_Allow_WAN_To_ZyWALL service includes HTTP and HTTPS, you will need to edit it:
- Navigate to Configuration > Object > Service > Service Group
- Remove HTTP and HTTPS from the member list.
2. Use Service Control (recommended for admin interface access)
Navigate to Configuration > System > WWW > Service Control.
For both HTTP (port 80) and HTTPS (port 443):
- Under Control service administration or Control service user, make sure the WAN zone is set to deny or removed from the access list.
- Ensure the LAN zone is set to accept.
Zyxel Tina
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
