Zywall 110 web admin not working
mlevasseur
mlevasseur Posts: 2 image  Freshman Member
I have a Zywall 110 that is currently working, meaning the firewall and VPN aspect work great.
However, I was messing around in the admin screen and adjusted some HTTPS setting. Which was bad as I no longer can access the web admin screen. The unit still works, just can't access the web admin.
Looking for ideas on how to get web admin working again. Do I have to do a full reset of the appliance and start over from scratch?
    PeterUK Posts: 4,376 image  Guru Member
    Fastest way to solve is link up a console cable with PuTTY
    login
    then
    configure terminal
    no ip http secure-server force-redirect
    write
    then you can use port 80 to login
