Flex500H IPSec VPN Issue
Fred_77
Hi all,
Here's my problem: It's not possible to connect remotely to the IPSec VPN (client to site) if the peer IP address is not the main one. (Configured as secondary in my scenario).
Never had problem with usg/atp using wan virtual intercaces.
Is it a normal behavior on H Series?
Regards
Lorenzo
This would be remote access VPN?
Don't use Incoming Interface as Interface use Domain Name / IP with 0.0.0.0 and NAT Traversal even if your not behind NAT your WAN IP or Domain Name.
See if that works
See if that works
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
