how to disable vpn
Hi @wguenten
To disable VPN configurations or services on your Zyxel security device, please follow the steps below based on your device type.
For Nebula Devices:
- Site-to-Site VPN: Navigate to
Site-wide > Configure > Security gateway > Site-to-Site VPN(orFirewall > Site-to-Site VPN) and toggle "Enabled" to "Off." For non-Nebula gateways, go toOrganization-wide > Organization-wide manage > VPN orchestratorand clear the "Enabled" checkbox. - Remote Access VPN: Go to
Site-wide > Configure > Security gateway > Remote access VPN(orFirewall > Remote access VPN) and select "Disable" for "IPSec VPN server" or "L2TP over IPSec VPN server." - VPN Orchestrator: In
Organization-wide > Organization-wide manage > VPN orchestrator, select the VPN area and choose "Disable" under "Topology."
For On-Premise Zyxel Devices (e.g., USG FLEX, ATP series):
- General VPN Service Disabling: To block VPN ports, go to
Object > Service > Service Group, then from "Default_Allow_WAN_To_ZyWALL", remove AH, ESP, IKE, and NATT services. - IPSec VPN Connection: Navigate to
Configuration > VPN > IPSec VPN > VPN Connection, edit the connection, and uncheck "Nailed-Up" to prevent auto-connection. - Auto Disable VPN Service: For models like ATP100, enable "Auto disable VPN service" under
Configuration → VPN → IPSec VPN → VPN Connectionto disable WAN UDP ports 500 and 4500 when no IPSec VPN rules are configured.
Zyxel Melen0 - Site-to-Site VPN: Navigate to
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
