Unjustified connections NWA50AX PRO access point
c777
c777 Posts: 14 image  Freshman Member
I purchased an NWA50AX PRO access point and configured it in standalone mode right out of the box, with update the latest firmware V7.10 (3) It works very well, no complaints on that front.
However, I am seeing some very surprising connections for a standalone device. It is connected to a firewall with Suricata on its interface, which is not happy.
I have a log on the access point that mentions a Nebula connection on TCP port 4335.
I think that in standalone mode, it shouldn't connect or be joined by other services such as ntp, update...
I never registered this access point on a Nebula portal.
Maybe there is a service running in the background. Can you help me shut it down properly and permanently?
Thank you.
Best regards,
    PeterUK Posts: 4,182 image  Guru Member
    The following SSH disable this:
    configure terminal
    netconf inactivate
    write
    to undo it
    no netconf inactivate
    write
