NWA130BE lost clients
Hi @DaveM84
According to the screenshot, it is more likely your AP can't sync the system time with NTP server. With the wrong system time, Nebula could not display the correct current info.
Please allow UDP 123 for *.pool.ntp.org & time.google.com on your router/firewall.
Zyxel Melen1
Hi @DaveM84
Zyxel Melen1 -
Thanks for the replay @Zyxel_Melen
Bingo! AP log say: "NTP server update failed."
But don't undestand why …
The switch use the same *.pool.ntp.org and its work, while the AP fails.
How can I investigate ?Thank you
Dave0 -
Hi @DaveM84
Please help to enable zyxel support access, we will help to check on this issue. I will send you a private message to confirm your device's mac address so we can find your org.
https://community.zyxel.com/en/discussion/14234/nebula-how-to-turn-on-zyxel-support-access
Update:Issue fixed by changing DNS server and NTP server.
Zyxel Melen0
- 237 Nebula Ideas
- 6.8K Security
- 746 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
