WLAN unstable and kernal panic after Update clients to IOS/MacOS26
Chris888
Chris888 Posts: 64 image  Ally Member
First Comment Friend Collector First Anniversary Community MVP
edited September 21 in Wireless
i use a WBE660s on latest firmware.
After Patch 7.20P2 the AP runs without any problems for a while.
After updating to IOS 26 and MacOS 26 the AP becomes unstable.
Every aprox 24h the 26-Clients could not connect to wlan anymore.
After disabling and enabling SSID in Nebula-App it works fine.
Last night i see 2 reboots with "Kernal panic" again.
Does any other user see this problems, too?
Regards
Christian
@Support: Remote Connect for you is enabled - if you want to have a look.
I opened a ticket as well.
  • Zyxel_Tina
    Zyxel_Tina Posts: 471 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers First Comment
    Hi @Chris888,
    We have received the diagnostic info file you provided and are currently reviewing and verifying it. We will update you as soon as we have any news or further information. Thank you for your patience :)
    Zyxel Tina
  • Chris888
    Short update: New firmware is installed. Keep on testing.
  • Chris888
    No further problems. Today i got a new firmware version, keep on testing.
  • Chris888
    Further kernal panics, but with Patch 3 everthing is okay now.
