USG Flex 200 and SSH commands
Is it possible to send commands to the USG 200 via ssh?
The use case is to activate and deactivate easily Security Policy and time schedules.
I have tried it with putty and plink.exe, but it didn't work:
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ + CategoryInfo : NotSpecified: (Using username "testadmin".:String) [], RemoteException + FullyQualifiedErrorId : NativeCommandError -- Keyboard-interactive authentication prompts from server: -------------------- End of keyboard-interactive prompts from server ---------------------------
Hi @IWAT ,
Put commands in a text file. Then run plink with the CLI file.
CLI file example:configure terminal hostname ABC address-object AAA 1.1.1.1 write exit exit
plink -ssh -no-antispoof admin@192.168.1.1 -pw mypassword < cli.txt
Hi @IWAT ,
Thank you!
It works.0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
