NWA210AX can't setup...
needhelp
needhelp Posts: 3 image  Freshman Member
edited September 2025 in Wireless
Got this router used at a sale but it doesn't seem to work. It turns on and I reset it using the hardware switch on the back but it is now not working. The light blinks yellow and green. WiFi shows Zyxel 01f1 but any attempt toget to the admin page doesn't work. Also doesn't work via network cable in either port.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,532 image  Zyxel Employee
    Hi @needhelp
    First, this is an access point, not a WiFi router. You still need a router/firewall to act as DHCP server.
    Since it is an used device, please press the reset button for ten seconds to factory default it. And reference this quick start guide to access it.
    NWA210AX_web_QSG_20210406_v04_outlined
    Zyxel Melen
  • Zyxel_Melen
    Hi @needhelp
    Zyxel Melen
  • needhelp
    edited January 27
    I don't really know what that means that "its an access point". I did eventually get this configured using a LAN cable. My issue was I couldn't even access the unit, however, once I gained access to the unit via the LAN cable plugged directly into my laptop, I got it reset, configured, and working. Now it is plugged in to my switch so I guess it is using my other WIFI router for DHCP. Thanks for sharing the manual, I will take a look at it. What kind of security options are there for the access point?
  • Zyxel_Melen
    Hi @needhelp
    Because some of user think the AP is just like the wifi router that you can get IP address when you connect to its WiFi. I was just want to clarify the difference, and its happy to see you can access to it.
    About the security options, I assume you are asking for the wireless security options. It supports "WEP/WPA/WPA2/WPA3"
    Reference:
    Datesheet: https://download.zyxel.com/NWA210AX/datasheet/NWA210AX_6.pdf
    User's Guide: https://download.zyxel.com/NWA210AX/user_guide/NWA210AX_V7.10_Ed2.pdf
    Zyxel Melen
